chime problem
Old Apr 18, 2006 | 08:59 PM
bixing's Avatar
Default chime problem
I just bought an Audi-A4 1.8T 1997 model.
it runs fine. But apart from flickering dashboard light..there are 2 small problems.
1. The chime doesnt work when I open the dorr with the ignition key in or with headlights on.
2. The front seats are tough to pull or push back and I feel as if its jammed and needs oiling or something like that..
Please advise.
Thank you
Old Apr 18, 2006 | 09:04 PM
Jeff's Avatar
Zombie Defense Force
Default RE: chime problem
1. maybe a fuse if blown but other then that its not a huge deal just remember to turn the lights off
2. Just get some oil in there and it should be fine, my passanger one was difficult to move and then it was oiled and now its super smooth
Old Apr 19, 2006 | 10:18 AM
bixing's Avatar
Thanx Jeff..
Yuhoo... sounds pretty easy...
Where do I check for fuses? I ll try to go thru the manual too before i keep asking these kindda silly ques... hehe
Now I am gonna have a cool time in my AUUUUDDIIIIIIIII
Old Apr 19, 2006 | 12:33 PM
Jestnomen's Avatar
6th Gear
I had the same problem with the chime. Very common problem which normally resides in the instrument cluster. The speaker is located behind it and often blows or stops working for whatever reason. You have to replace the entire cluster, which is expensive and not worth it.
Old Apr 19, 2006 | 12:50 PM
dankhound's Avatar
Make sure your interior lights are functioning properly when the door is opened or closed. You could have a drivers door switch that doesnt know its opening.
Old Apr 20, 2006 | 01:54 AM
bixing's Avatar
I checked ... my interior lights are working fine...
Its only that my seat belt chiming and headlights on with open door chimin doesnt work.. I hope it all from the same thing not a separate things.
Rest is real cool.
I was actually looking for a cd-mp3 player which cud fit in place of the factory 'DELTA' radio+cassette player. Is there any that fits exactly int the same dimensions.. or something which increases car's grace??
All kinds of ideas are welcome.
thanx
skycladgod
Feb 23, 2013 11:14 AM
vtraudt
Sep 10, 2011 12:36 PM
Audacity
Aug 3, 2009 05:49 PM
delphi_wiz
Jul 4, 2006 12:09 AM
bixing
Apr 27, 2006 09:31 PM
