chipped ecu?
what what it mean to buy a chipped ecu? Does that mean you can just have it installed and ur all set? what is the difference between that and just buying a chip for ur ecu? would you recomend buying a chipped ecu?
RE: chipped ecu?
I think if you use the search you can find answers to easy questions like that... I for one, have no clue.. Whats a chip?
RE: chipped ecu?
there are two kinds... the ones you solder on (like GIAC) or the ones that are direct ODB2 port flash (REVO/APR)... i think your talking about the solder-ons.
RE: chipped ecu?
ORIGINAL: onepoint8tee I for one, have no clue.. Whats a chip? A chip will remap the ECU to give you better performance gains such as acceleration, hp, etc. Basically you are optimizing the ECU for peak performance. GIAC, APR are probably the leaders in the Audi chip market. Do some searching on those terms and you will find tons. |
RE: chipped ecu?
GIAC has a flash as well depends on the year
RE: chipped ecu?
ORIGINAL: afruss2007 ORIGINAL: onepoint8tee I for one, have no clue.. Whats a chip? A chip will remap the ECU to give you better performance gains such as acceleration, hp, etc. Basically you are optimizing the ECU for peak performance. GIAC, APR are probably the leaders in the Audi chip market. Do some searching on those terms and you will find tons. |
RE: chipped ecu?
a chip remaps your fuel, timing and boost if its a 1.8t. There are chips for a 2.8 too. Give details about your car when youre asking performance related questions. And use the search... I beleive B6's use the OBD port for flashing, but with a B5 flash, they have to take your ecu out for bench flashing. If its a pre 2000/DBC, they take your ecu appart and solder it in.
RE: chipped ecu?
I was joking dude... Check my sig. Haha ... sorry bout that ... wasn't very clear with my joke ... no laugher there now ... win some and lose some ... :D |
RE: chipped ecu?
can GIAC flash a b6 a4 or do i gotta mail them the damn chip
RE: chipped ecu?
B6's can be flashed where are you located ?
