Clear Corer Mod Question?
Old Jun 30, 2007 | 10:59 PM
JayStang's Avatar
Default Clear Corer Mod Question?
Hey Guys, I'm about to attempt to do the clear corner mod on my B6. I had a quick question before I start though. In most of the write up's I have found it says to use a dremel tool with a grinding bit. I do not own a dremel tool. Would this be possible to accomplish with a normal drill? What type of grinding tool is needed? If anyone would explain this step in further detail that would be helpful.
Also what write up do most people use for the B6? I've been reading the one on audidiy.com but are there others that might be better?
Thanks,
~Jamie
Old Jun 30, 2007 | 11:18 PM
Lazer Viking's Avatar
Default RE: Clear Corer Mod Question?
yes, you can use a drill, you just need to line up the tab in the back of the housing, and make a whole.. i found it easier to start with a bigger bit, and make the hole.. then move the the smallest bit you have and use the whole to slowly grind down the tab from the top of it working in, untill you get far enough so you can move the insert.. just take your time and keep trying to move the tab till you have enough off
Old Jul 1, 2007 | 09:42 AM
JayStang's Avatar
Thanks for the advice. So a grinding bit is not needed at all?
Old Jul 1, 2007 | 10:31 AM
nope, drill bit works fine, just a bit more effort
Old Jul 1, 2007 | 10:46 AM
JayStang's Avatar
great! thanks.... here goes
Old Jul 1, 2007 | 10:57 AM
JayStang's Avatar
One more question.... how do i know if i have "auto leveling" lights. I see the steps are a bit different if you don't have them. Is this only on the stock xenon lights?
Old Jul 1, 2007 | 03:07 PM
i belive so, yes
Old Jul 1, 2007 | 03:58 PM
jojoampt's Avatar
did you check out a4mods .com? thats the tutorial i used to do it to my b6 and i highly reccomend it. if youve already done it congrats, if not check out a4mods.com.
Old Jul 1, 2007 | 04:26 PM
AteUrV8's Avatar
cc mod on b6's are hot diggity dam
Old Jul 1, 2007 | 05:44 PM
Notahondaowner's Avatar
I followed the steps on a4mods. I used a small drill bit on my b6 lights. It was a bit of a pain but it was well worth it. Most annoying part for me was getting the damn amber piece out of the lens after I had it loose.
