climate control not very hot..!!!!
Old Mar 9, 2005 | 06:10 PM
blast's Avatar
Default climate control not very hot..!!!!
my climate control works fine all the display works
except on HI mode or up full i dont seem to get great heat from it, as in compared to normal hot and cold ***** in any other cars
is this the way it's suposed to be...????
I have never had a climate control in a car before so i could just be me...??
Old Mar 9, 2005 | 06:15 PM
Froggy9682's Avatar
Default RE: climate control not very hot..!!!!
I just got my a4 saturday and i've sorta noticed the same thing (i used to have a taurus and it's was super hot/cold), i think that's just how the climate control works because the air temp it blows adjusts to a certain temp that you want to maintain in the car, not necessarily the temp of the air itself. If you let it go on high temp for awhile, it should warm up the car pretty toasty and rather quickly, at least that's what i've experienced, but the air temp never seems that hot. an audi mystery? who knows!
Old Mar 9, 2005 | 06:43 PM
Karl's Avatar
Hi blast welcome to the Forum. First off what year is your car? If its older. it would most likely be the heater core starting to go out. I have a 96 A4 and I get awesome heat from it.
Old Mar 9, 2005 | 07:13 PM
Jestnomen's Avatar
6th Gear
I have excellent heat from my 97. It is not your climate control, it is something else. As redgoat said, could be a blocked heater core, or the flaps that regulate the air mixture are not working.
You can disconnect the heater line hoses and flush it out with a garden hose.
Old Mar 9, 2005 | 07:34 PM
blast's Avatar
hi all
the car is 1996
i have felt the inlet and outlet hoses that run to the heater and they are quite hot, so i wouldnt think it's a blockage
but deffinaitly no where near the same heat inside as the hoses.
im baffles
Old Mar 9, 2005 | 07:53 PM
a4autocrossr's Avatar
my '00 turns into a freaking OVEN on HI...and with the seat heaters on...my *** roasts too!!
--E
Old Mar 9, 2005 | 07:58 PM
Jestnomen's Avatar
6th Gear
http://www.audiworld.com/tech/int5.shtml#DiagCodes
Read this article and see if you can pull any codes.
Old Mar 9, 2005 | 08:08 PM
blast's Avatar
I'll try the hose on the inlet and outlet pipes tomorrow and se if that help.
If not i'll take it from there.
Old Mar 10, 2005 | 03:07 PM
blast's Avatar
well now
i flushed the inlet/outlet heater matrix and was all clear no blockage.
and then gave the cooling system a flush. it didnt help it that i could tell.
then i went through the climate control codes as sugested by a kind member and found no faults with the c/control
then took the c/control out an cleaned all connections. Still not a great heat
im stumpted
Old Mar 10, 2005 | 05:53 PM
Jestnomen's Avatar
6th Gear
You filled it back up with G12 and distilled water right?
Next step would be to check the flap motor. How you go about this is beyond me though.
