clutch dieing?
Old Nov 4, 2007 | 08:26 PM
turbo kraut's Avatar
Tech Guru
Default clutch dieing?
i normally do search, but i didn't this time, and it is because i think this issue is a little different than most...... help would be appretiated
so i have noticed the last few times i have gotten on it hard(the clutch that is)...... i spool the turbo, take it to 0psi..... probably about 3-3500 rpms....... take off.... run it out of first, shift to second, which is 3 or 4 grand and when i hit 4500-5000 it just kind of sits there and then seems like it takes off....... question is that the clutch slipping? it drives fine after that and anyother time...... i kind of think it is, just wanna make sure.... and maybe with my last statement, i answered my on question, just wondering
Old Nov 4, 2007 | 08:31 PM
onepoint8tee's Avatar
Default RE: clutch dieing?
ORIGINAL: turbo kraut
If the clutch was slipping, the rpm's would jump.
Old Nov 4, 2007 | 08:38 PM
sdsteez's Avatar
can you feel it boggle?
Old Nov 4, 2007 | 08:40 PM
Tech Guru
ORIGINAL: onepoint8tee
ok, it does sit there, maybe a second or 2, then jumps right up to 5500 - 6000, then i shift and have no problems in any other gear, what could this be?
Old Nov 4, 2007 | 08:51 PM
cincyTT's Avatar
I'm make believe
You have a 99.5 or older DBC car dont you?
Old Nov 4, 2007 | 08:59 PM
Tech Guru
actually an 01 1.8t qm
Old Nov 4, 2007 | 09:03 PM
cincyTT's Avatar
I'm make believe
in that case, check and clean your TB, it could be sticking or just need a TB alignment
Old Nov 4, 2007 | 09:12 PM
Tech Guru
how do i go about an alignment? without going to dealer?
Old Nov 4, 2007 | 09:14 PM
cincyTT's Avatar
I'm make believe
Vagcom or the dealer may do it for you if you ask. People say undoing the battery will work, but i have also heard that it doesnt. Couldnt hurt to try.
Old Nov 4, 2007 | 09:15 PM
Turn the key to ON without starting and waita few mins. You should be able to hear the TB clicking within the first minute. Or vag com.
