clutch with lightweigh fly wheel suggitions??
Old Apr 11, 2007 | 10:16 AM
kraylon's Avatar
Default clutch with lightweigh fly wheel suggitions??
i am looking to get a light weight fly wheel from awe the fly wheel is used but i need to know wht clutch in a stage 2 is going to work well with the fly wheel any suggitions or links would be great
Old Apr 11, 2007 | 12:05 PM
hb972.8q's Avatar
Default RE: clutch with lightweigh fly wheel suggitions??
i would get a spec clutch
Old Apr 11, 2007 | 01:10 PM
kraylon's Avatar
any certain one? i noticed that some say they work with light weight flywheels and others are for normal what makes them different?
Old Apr 11, 2007 | 01:49 PM
FASTER's Avatar
Tech Slut
i have spec clutch and spec flywheel. i just blew up my tranny and old awe stage 2 clutch... as long as its a single mass u will be happy.
Old Apr 11, 2007 | 02:33 PM
kraylon's Avatar
how do you tell if it is a single mass??
Old Apr 12, 2007 | 04:42 AM
kraylon's Avatar
is there alot of differance between a south bend and a sach clutch besides color??
Old Apr 12, 2007 | 06:41 AM
Lazer Viking's Avatar
factory has a dual mass flywheel, which helps to dampen engine vibrations
Old Apr 12, 2007 | 10:05 AM
kraylon's Avatar
i have tried to find a pic of the oem flywheel so i can be sure that the lite weight one im looking at is really a lite weight single mass
Old Apr 16, 2007 | 12:50 AM
Jays TT's Avatar
I just put in a Spec Stage 2+ with Alum Fly wheel.With the J valve and APR chip. I like the clutch! Very easy to use with alot of grip and also the fly wheel revs up nice! The only down fall is the lighter wheel as a tingie noise to it while in idle, but as soon as you push the clutch in the noise goes away. It seems to be about a 8 pound diffrence in flywheel weight.
Old Apr 16, 2007 | 01:03 AM
A4Rollin's Avatar
yah hes right on the weight difference. I have had an Amco lightweight flywheel and South Bend stage 2 clutch in 2 audis now and love them. Its a great combo and runs and operates well. I have noticed no problems with them. I have that combination on my 2001 A41.8tq and am running great. (Also,) I had this on my old A4 with K04 and GIAC K04 chip and it worked great!
