[size=4]The other day i was driving and went to upshift into third and out of no where when i pressed the clutch and relesed it it didnt come up just stayed to the floor. i got it towed and when i got back into my car again the clutch worked fine for about a week and it happened again. so i tried to bleed the lines that worked for a month and it happened again what can this be Please help me
Wow. thats like the wierdest thing...hmm
when the clutch sticks, can you pull it up with your hand as if there was no spring, or is it like stuck there as if the clutch was stuck on something?
I can pull the clutch up but it falls loosley to the ground when lightly pressed and eventualy in about an hour starts working fine. what can it be
sounds like something is stuck...could be your master valve or whatever for your clutch. it sounds like the valve gets stuck sometimes and has a slow leak when it does.
or i could be completly wrong also....
Do you think it could be my slave cylynder
RE: Clutch stays to floor
Weird problem and interesting.
I searched it but haven't found anything great yet. Some other people have run into this, but I don't see a definite problem/solution. Check out these posts.
https://www.audiforums.com/m_95233/tm.htm
https://www.audiforums.com/m_117109/tm.htm
I just got the slave cylynder replaced but i will have to wait and see if it happens again cause it only happens once in a while
This just happened to my in my 06 with only 22k miles....what was the final solution????
Thanks in advance.
Thanks in advance.
