Clutch stays to floor
Old Oct 9, 2006 | 10:32 PM
raffysaudi's Avatar
Member
Default Clutch stays to floor
[size=4]The other day i was driving and went to upshift into third and out of no where when i pressed the clutch and relesed it it didnt come up just stayed to the floor. i got it towed and when i got back into my car again the clutch worked fine for about a week and it happened again. so i tried to bleed the lines that worked for a month and it happened again what can this be Please help me
Old Oct 9, 2006 | 10:34 PM
AudiCross's Avatar
Default RE: Clutch stays to floor
Wow. thats like the wierdest thing...hmm
when the clutch sticks, can you pull it up with your hand as if there was no spring, or is it like stuck there as if the clutch was stuck on something?
Old Oct 9, 2006 | 10:43 PM
raffysaudi's Avatar
Member
I can pull the clutch up but it falls loosley to the ground when lightly pressed and eventualy in about an hour starts working fine. what can it be
Old Oct 9, 2006 | 10:47 PM
AudiCross's Avatar
sounds like something is stuck...could be your master valve or whatever for your clutch. it sounds like the valve gets stuck sometimes and has a slow leak when it does.
or i could be completly wrong also....
Old Oct 9, 2006 | 10:57 PM
raffysaudi's Avatar
Member
Do you think it could be my slave cylynder
Old Oct 9, 2006 | 11:08 PM
TDRILL's Avatar
Weird problem and interesting.
I searched it but haven't found anything great yet. Some other people have run into this, but I don't see a definite problem/solution. Check out these posts.
https://www.audiforums.com/m_95233/tm.htm
https://www.audiforums.com/m_117109/tm.htm
Old Oct 10, 2006 | 12:01 AM
wood_e's Avatar
Probably your slave cylinder
Old Oct 10, 2006 | 10:07 PM
TDRILL's Avatar
BUMP
Make sure you post back on this whether it was the slave cylinder or something else.
Old Oct 12, 2006 | 09:27 PM
raffysaudi's Avatar
Member
I just got the slave cylynder replaced but i will have to wait and see if it happens again cause it only happens once in a while
Old Nov 8, 2014 | 09:14 PM
heffymontana's Avatar
This just happened to my in my 06 with only 22k miles....what was the final solution????
Thanks in advance.
krazzz
Nov 27, 2011 12:06 AM
audi_tt_4u
Jan 21, 2011 09:42 PM
raffysaudi
Oct 10, 2006 06:35 PM
Ostojo
Aug 28, 2006 04:00 AM
RayS4
May 24, 2004 01:35 AM
