Code reader put up 10 codes!!! cool right
Old Jun 23, 2007 | 04:29 PM
Noobinator's Avatar
Default Code reader put up 10 codes!!! cool right
Ok so I finally got my code reader and it threw 10 codes at me at first. I have a 2000 Audi a4 1.8T
Here are the codes at first:
17956
16684
16685
16687
16688
16487
16501
16524
16712
18010
Then I reset it and it gave me just this code:
17956 Boost Pressure Regulation Valve (N75): Open Circuit : P1548
I dont know what to do know or how to fix that? Can anyone help?
Old Jun 23, 2007 | 04:36 PM
techbod's Avatar
Default RE: Code reader put up 10 codes!!! cool right
turbocharger wastegate regulating valve open circuit possible causes are wiring open circuit, wastegate regulating valve ( N75 you guys call it ) dont bother about all the other codes they were probably caused by this problem
Old Jun 23, 2007 | 04:46 PM
auditech79's Avatar
+1 N75 valve is probably the problem
Old Jun 23, 2007 | 04:54 PM
Noobinator's Avatar
how do I go about fixing this?
Noobinator's Avatar
And also would this problem cause the car not to run because I cant get it to run.
Old Jun 23, 2007 | 05:22 PM
Noobinator's Avatar
Its also giving me 18010 again now to. What do I do?
Old Jun 23, 2007 | 05:44 PM
techbod's Avatar
16487 = MAF short to positive
16501 = ECT wiring short to ground
16524 = heated o2 sensor 2 bank 1 wiring short
16712 = knock sensor 1 bank 1 wiring short to positive
18010 = ECM voltage low from the battery wiring open circuit, blown fuse
16684/5/7/8 = multiple misfire detected.
wiring being the issue here but since all the other codes didn't come back the N75 is the most likely issue
Old Jun 23, 2007 | 05:46 PM
techbod's Avatar
is the battery fully charged? check the connections and any fuses
Old Jun 23, 2007 | 05:51 PM
Noobinator's Avatar
ok i now have 3 codes here they are:
18010 Power Supply (B+) Terminal 30 - Low Voltage
or Power Supply Terminal 30: Voltage too Low : P1602
00532 Transmission Control Module Relay - Supply Voltage (B+) Malfunction Low Battery or Bad Ground
or Supply Voltage (B+)
or Supply Voltage B+
Im gonna go check the fuses right now. Can u tell me how to fix any of these problems
Old Jun 23, 2007 | 05:57 PM
techbod's Avatar
[IMG]local://upfiles/12092/0EF4952212264CC9AECBE886042E0D3F.jpg[/IMG]
