Codes - As promised just a little late.
Old May 14, 2007 | 08:18 AM
ironman's Avatar
Default Codes - As promised just a little late.
Controller: 8E0 909 559 D
Component: 3.0L V6/5V G 0003
Coding: 0016711
Shop #: WSC 63351
2 Faults Found:
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 008 - Implausible Signal - Intermittent
16805 - Warm Up Catalyst: Bank 1: Efficiency Below Threshold
P0421 - 001 - Upper Limit Exceeded
Readiness: 0000 0000
Old May 14, 2007 | 08:30 AM
kpatz's Avatar
Default RE: Codes - As promised just a little late.
Your post-cat oxygen sensor on the passenger side needs replacing, or has a loose connection.
Chances are the catalyst code is related to the O2 sensor code.
Old May 14, 2007 | 09:07 AM
ironman's Avatar
any idea where exactly that is located, i know post cat but where is the bank along the exhaust
Old May 15, 2007 | 01:18 PM
ironman's Avatar
Can anyone give me a diagram of where this would be, i want to change it but i dont know where to look
Old May 16, 2007 | 09:22 AM
ironman's Avatar
so no one can help me
Old May 16, 2007 | 10:31 AM
BeringCB6's Avatar
I can't get you a diagram, but yor post-cat sensor should be found on the pass side just under the plastic cover. Remove the large plastic piece in the corner of the engine bay and the intake hose and you should see it. The post cat sensors have a 4-wire colored connector on the firewall, green for the pass side. Drivers side stuff is hidden under the coolant bottle. You can move that out of the way by removing one screw and the senseor wire underneath. Don't drain it. Drivers sider post cat sensor has a brown connector. Hope that helps.
Old May 16, 2007 | 11:17 AM
ironman's Avatar
Yes it does Thanks
Old May 16, 2007 | 09:19 PM
BeringCB6's Avatar
FYI- I just did both of my post-cat sensors today- it's a real bitch! Especially the passenger side. You must have the O2 sensor socket and a seriously long extension. Don't be in a hurry, and I hope you don't have huge hands, or you won't get at the pass side one. I think it took maybe an hour and a hlf or so, that includes splicing the wires together. (I used the universal sensors)
Old May 16, 2007 | 09:27 PM
Trey25's Avatar
Did you use the bosch universal sensors, and have you noticed a difference in fuel economy?
Old May 18, 2007 | 11:17 AM
BeringCB6's Avatar
Those are the ones I used. I got them off of ebay, they were new but really cheap at 25 bucks each so I am skeptical. So far so good though. It's too early to tell on the fuel econ, I just did it yesterday and haven't driven much, but my check engine light is out for a change!!
