AudiForums.com
-   Audi A4 (https://www.audiforums.com/forum/audi-a4-8/)
-   -   cold start, pls help (https://www.audiforums.com/forum/audi-a4-8/cold-start-pls-help-8179/)
silver_rings Apr 7, 2005 04:09 PM
Problem with intermittent cold start issues. Just bought a4 2001 1.8t Q, 3 months ago, still under factory warranty. Will bring to dealer but is there any simple things I could do? thnx
ImolaS4 Apr 7, 2005 08:55 PM
RE: cold start, pls help
Welcome to Audi Forums silver_rings!
Since you're new... check out the START HERE! (click this link) link to get a rundown of the lingo/vocab here at audiforums.
Then be sure to search the archives when you have a question. Chances are the question has been asked before (probably several times) and the archives will have plenty of information to answer your question. If you still need answers, please feel free to ask questions.
Don't feel intimidated; we are all a bunch of pretty cool guys (and gals). Feel free to post advice, comments, ideas, suggestions, and even pics.
Not really. Might as well let the dealer handle it. There may be some TSB's that weren't addressed by the first owner.
silver_rings Apr 8, 2005 02:21 AM
thnx for the warm welcome!
brrman Apr 8, 2005 04:13 AM
possible coolant temp sensor problem. thas a cheap part.
Sebass Apr 8, 2005 04:21 AM
brrman, could a faulty sensor cause unnecessary coolant burning? I just got a code about the engine coolant temperature circuit high...but Bentley has no recommended solution for the problem...I am almost positive now I am burning a small amount of coolant. It goes from about between the arrows on the reservoir to about 3/4 of the way down the bottom one in about a month.
ImolaS4 Apr 8, 2005 04:42 AM
Actually, a failed sensor will cause the ecu to back off on the timing because it thinks the engine is getting too hot.
david9999 Apr 8, 2005 11:33 PM
Ummm,
coolant doesn't burn. It leaks. Either you are leaking externally, or internally
Check your oil. If it looks like coffee with cream, or if you have gunk in your oil filler, you likely have a blown head gasket. Are you blowing any smoke or steam?
Are you leaking coolant from anywhere? Front of engine? Likely water pump. Get if fixed ASAP.
Hoses? Radiator?
