collar bolt on axle possibly stripped.
Old Oct 3, 2007 | 05:09 PM
skinnyhb's Avatar
Default collar bolt on axle possibly stripped.
alright, my collar bolt is the 14mm allen, but the wrench is not a great fit in there as it looks to be fairly stripped. any suggestions on how to get it off? perhaps taking it to a shop who can break it loose for me?
kenny
Old Oct 3, 2007 | 05:11 PM
hiwords's Avatar
Default RE: collar bolt on axle possibly stripped.
im sry wut's the collar bolt. is it the one that holds the spindle to the cv halfshaft?
Old Oct 3, 2007 | 05:13 PM
Bondga's Avatar
if its teh bolt for your axle then its not an allen its a tripple square( like a torixs with more points)
Old Oct 3, 2007 | 05:15 PM
hiwords's Avatar
no the bolt that holds the spindle to the cv halfshaft is an allen one. at least on my quattro tranny it is. ur fwd might be diff lol
Old Oct 3, 2007 | 05:21 PM
skinnyhb's Avatar
its the axle bolt in the middle of the wheel that im trying to remove so i can do my control arms and cv boot.
Old Oct 3, 2007 | 05:22 PM
skinnyhb's Avatar
and its definately not a triple square.
Old Oct 3, 2007 | 05:27 PM
hiwords's Avatar
ok we're on the same page then. put up a pic of how bad it is. spray some pb blaster on it too but don't put a torch on it because the heat can damage the bearings. see if u can get a vise grip plier on it and then turn while using the 14mm too. there's really not much u can do. make sure u replace the bolt though.
Old Oct 3, 2007 | 05:28 PM
Bondga's Avatar
yeah nvm that is an allen i was talking the bolts that hold the axle to the tranny.
Old Oct 3, 2007 | 05:45 PM
auditech79's Avatar
If you're trying to take out the "hub" bolt that holds the CV axle to the spindle with a 14mm allan then your gonna strip it because its a 17mm hole.
Old Oct 3, 2007 | 05:49 PM
hiwords's Avatar
o ya. if u do indeed strip it. see if u can sumhow weld the allen socket to it and then u'll get it out for sure
