concerned about car
Old Oct 12, 2006 | 04:05 AM
spectrum's Avatar
Default concerned about car
My car is starting to make noise a shhh sound when in between gears. The noise is most noticeable when in neutral and shifting into gear.
I am trying to get an idea of what it could be before taking in. I don't want to jump into it blindly. Unless this is a normal sound
which then I wouldn't have to worry. Also the noise is heard the loudest when holding the shifter all the way right before going into fifth. There
are no check enginge lights on. This sound cannot be reproduced at a stop. Any help would be appreciated, thank you. I am driving a '03 A4 1.8t with 75,000 miles
Just wanted to update the sound increases in noise with speed no grinding a steady shhh sound could be associated with something else?
Old Oct 12, 2006 | 04:17 AM
spectrum's Avatar
Default RE: concerned about car
what are the symptons of low fluid and is the hydroliic fluid connected to another component of the car brakes power steering?
PandaXpress's Avatar
it could be a hose, is it really loud
i had the same problem as you check this hose
Old Oct 12, 2006 | 04:21 AM
spectrum's Avatar
yea, it's noticeable when the windows are closed low radio. I'm not very familiar with hoses what's the position on engine?
AudiCross's Avatar
But panda, that would happen under boost. when he is between gears, there is no boost.
Old Oct 12, 2006 | 04:23 AM
spectrum's Avatar
maybe vacum to the clutch?
Old Oct 12, 2006 | 04:27 AM
hes said its happen when shifting im assuming he lets go of the gas
but ya i think ur rite
Old Oct 12, 2006 | 04:31 AM
spectrum's Avatar
your right no gas coasting, if I hold the shifter right or left it is continuos noise it. If I am just shifting normal gear to gear it's louder from fourth to fifth.
Old Oct 12, 2006 | 04:41 AM
spectrum's Avatar
is there some type of assist a system that helps the driver when shifting?
Old Oct 12, 2006 | 04:43 AM
AudiCross's Avatar
I dont believe so. the only thing i can think of is maby something to do with your synchros. like they are enguaging partially before being put into that gear causing a noise. but i really dont see how that could happen.... is there a rough feel at all when you do this? or is it just a noise.
