confused... how bout diode mod with K04???
Old May 26, 2007 | 07:08 PM
Karl's Avatar
Default RE: confused... how bout diode mod with K04???
umm the diode mode? What are you talking about??
Old May 26, 2007 | 07:14 PM
B5luver's Avatar
lol diode modification, umm probably easiest way to explain is to do a search, I'm to lazy right now to go through it. Basically you put a diode (like a resistor) on your map sensor so that the ecu doesn't go into limp mode under higher than stock boost numbers, and with a manual boost controller you can put it up to about 15-18psi on factory software, thus beating the need for a chip. But search it to get a better understanding.
Old May 27, 2007 | 01:50 AM
sean1.8t's Avatar
ORIGINAL: B5luver
Money isn't an issue, I'm just seeing if there is an alternat way of doing it, like the diode mod instead of chipping the K03.
if money isn't an issue then spend the money to DO IT RIGHT! i can not stress this enough
Old May 27, 2007 | 02:20 AM
Karl's Avatar
ORIGINAL: B5luver
I have a feeling you are talking about those crappy ebay "chips"..
Bad idea. dont screw up your car, just get it chipped
Old May 27, 2007 | 03:09 AM
Jeff's Avatar
Zombie Defense Force
+1 for get a ko4 and the right injectors for the sw
Old May 27, 2007 | 11:26 AM
onepoint8tee's Avatar
ORIGINAL: Redgoatâ„¢
Same concept, but very different and supposedly effective... I think there is a sticky on the subject, Mr. ADMINISTRATOR~
Old May 27, 2007 | 11:37 AM
fenderstrat1184's Avatar
this is what he's talking about https://www.audiforums.com/m_535568/.../tm.htm#543444
Old May 27, 2007 | 12:06 PM
  #18
cincyTT's Avatar
I'm make believe
man, thats a nice write up...
If you have a ko3s i would say keep the ko3 chip and getting a adj fpr. But going from a ko3 to a ko4 will be a bigger jump. You can make it work, but specific sw and fueling would give you better results than just increasing turbos and fuel pressure. You can always give it a shot, but i wouldnt risk it without a way to monitor a/f ratios.
Old May 27, 2007 | 02:18 PM
  #19
B5luver's Avatar
What about using Lemmiwinks, couldn't I use that to tweak a few things on the factory software... I agree probably absolute best way to go is just buying software, but I'm exploring other routes first. Lets put our heads together and figure something out!
Old May 27, 2007 | 02:27 PM
  #20
Karl's Avatar
yeah you could use Lemmiwinks if you have REVO software
