Control Arm Bushings
Old May 16, 2006 | 01:43 AM
thizzwatitiz's Avatar
Default Control Arm Bushings
How much is it to replace my control arm bushings on my 2000 A4 with sport suspension? My car has been squeeling like crazy when i turn or go over a bump, and i believe that this may be the solution, correct me if i am wrong
Old May 16, 2006 | 01:45 AM
flyboy's Avatar
Default RE: Control Arm Bushings
The bushing don't really come out, you will need to replace the controll arm. If you can isolate witch one it is then go here. www.ecstuning.com , they will have what your looking for.
Old May 16, 2006 | 11:11 AM
north5995's Avatar
Don't replace just one control arm, if you are in there replace the uppers (Which are what is probably squeaking), then the sway bar links which are probably destroyed from the loose upper CAs. Tie rods have known to be an issue too - preventative maintenance. You can get kits for this.
Priceco
Dec 13, 2013 09:51 AM
Ultim8gamr
Jan 22, 2009 12:00 AM
Herns4
Aug 26, 2008 03:00 PM
svroom
Jul 24, 2008 11:59 PM
andrei
Aug 16, 2007 07:47 PM
