Control arms, it there a better brand to go with?
Old Sep 17, 2006 | 03:08 AM
Boober's Avatar
Default Control arms, it there a better brand to go with?
hey everyone, just bought my car and just found out the control arms need to be replaced (front upper). the car has pretty low milage and i was wondering if i should replace both upper control arms now, and if there is a better brand to go with so they don't go bad again. thanks
Old Sep 17, 2006 | 03:15 AM
sandman's Avatar
Default RE: Control arms, it there a better brand to go with?
meyle makes a good oem kit.
http://www.ecstuning.com/stage/edpd/...ubcategory=OEM
Old Sep 17, 2006 | 06:08 AM
captcaos2002's Avatar
I used Meyle... good stuff
Old Sep 17, 2006 | 07:36 AM
Boober's Avatar
from what i can tell the uppers are what go bad, when the car was on a lift there was play in the uppers...couldn't tell about the lowers though. do the lowers go out just as much as the uppers? thanks
Old Sep 17, 2006 | 01:34 PM
CRAZYHAWK's Avatar
Make sure the tie rod ends are good.
Old Sep 17, 2006 | 03:12 PM
I had to replace my lowers before my uppers... the control arms (all) are one of the areas on the A4 that should be aftermarket parts.
Old Sep 17, 2006 | 03:28 PM
V8Mustang's Avatar
ORIGINAL: Boober
How can you tell if they need to be replaced? Can you feel a looseness when driving or tire wear?
Old Sep 17, 2006 | 04:12 PM
harryc's Avatar
I have had to replace 4 uppers only - lowers are still ok after 115k miles
ORIGINAL: Boober
Old Sep 17, 2006 | 05:29 PM
Boober's Avatar
ORIGINAL: V8Mustang
ORIGINAL: Boober
i can hear it when i hit dips and bumps, i took it to a place and they put it on a lift and he showed me, by moving the tire back and forth with his hands, that there was play in the control arms.
Old Sep 17, 2006 | 05:31 PM
Boober's Avatar
ORIGINAL: harryc
how can you tell if the lowers are bad?
