My conv top doesn't work on my 05 A4 1.8, I have been told that it needs a comfort control module installed to fix the problem. I am a single lady trying to get all repairs done to this car so I can drive it. I can't get a much needed new windshield until the top can go down. Could someone please tell me if this sounds correct?
Hi. There are a number of reasons why the roof may not be opening and the comfort control module isn't a common one. Do you know if the fault memory was read and what code was logged? The most common faults are one of the various roof position switches. If you can offer any more info I could advise you further.
Regarding having your windshield replaced, you can open the roof manually using the T-handle provided. It is located behind the fuse box cover at the end of the dash, on the drivers side. Your owners handbook will explain how to do this. Hope this helps.
Thank you so much. I will check these things out.
