Coolant Question
Old Jan 17, 2007 | 07:38 PM
  #21
ruby's Avatar
Default RE: Coolant Question
I dont know why you are saying that you NEED to use audi g12. g12 is not chemically different than some other antifreezes. When my mechanic fixed mine, he put in some stuff called 'zerox extreme life'(also pink) from napa which is lifetime antifreeze, and that was almost 30,000 miles ago.
Old Jan 17, 2007 | 07:57 PM
  #22
NuYorka103185's Avatar
so what about that 50/50 blend it says ALL makes ALL models from prestone
Old Jan 18, 2007 | 10:14 AM
  #23
david9999's Avatar
Why risk trouble to save 3 dollars.
BTW, to the original poster: adding coolant doesn't solve the problem. It gets rid of the SYMPTOM. The PROBLEM is that you have a coolant leak somewhere.
Find it.
Old Jan 18, 2007 | 01:08 PM
  #24
ORIGINAL: david9999
Find it.
I dont think so, my car is not leaking anything. Is there a chance it oculd just be a sensor b/c I noticed it does it in the morning when it is cold but not in the afternoon when it is warmer. Dont know if that means anything
Old Jan 18, 2007 | 11:35 PM
  #25
jonrp's Avatar
yeah, dont worry about the coolant type at all. i make a lot of money replacing heater cores and radiators from people"helping" their car by adding anything other than g12 or water to top them up. if everybbody looked at thebottle or read their manual i might not have as much work.. the ONLY time i have ever seen rust in a g12 system is when someone has used the incorrect coolant.. so go ahead, sludge it all up for me..
same goes for not using synthetic in ALL 1.8t engines.. may be cheaper now, but after a while you will have to pay me at least $1000 to repair your oil light on and clatter.. so go ahead, take it to jiffy lube
Old Jan 18, 2007 | 11:57 PM
  #26
tractioncontrol's Avatar
^^ +1 The silicates in aftermarket coolant breakdown hoses and the tap water most people use rusts radiators and heater cores. The only time I replace radiators, hoses and heater cores at work is when people changed the fluid with aftermarket coolant.
eddiefury
Nov 9, 2008 07:34 AM
bkcox_S4
Jul 3, 2008 01:56 PM
Armenian
Jun 22, 2007 06:29 PM
a4anonymous
Sep 26, 2005 06:56 PM
skull10
Jan 16, 2005 01:04 PM
