Coolant question
Old Sep 19, 2007 | 11:56 PM
viktor008's Avatar
Default Coolant question
I was wonderingabout thetype of coolant I need to use in my 96 A4. Bentley manual says it's the blue G11, but everyone here swears by the pink G12 coolant. Which one should I use?
Old Sep 20, 2007 | 12:05 AM
chaos92287's Avatar
Default RE: Coolant question
never heard of blue g11[&:] must be for older audi's
honestly you can run g12, universal yellow, or even the green stuff. you just cant mix anything with g12 except water.
Old Sep 20, 2007 | 12:06 AM
auditech79's Avatar
Yeah the old school coolant is in pretty much anything before 96, G12 should be ok.
What color coolant is in there right now?
Old Sep 20, 2007 | 12:31 AM
viktor008's Avatar
Right now thethere is some sort of universal yellow coolant that needs to go. I thing that's causing my problem with the heat in the winter - when the RPM's are up there is anok heat, but low RPM's result in cool air coming from the vents. The coolant temp is exactly in the middle where it should be so I don't think is the thermostat. I few peopleon this forumdescribed the same problem with the heat but no one gave a straight answer. Anway, the coolant must be flushed the question is which one, G11 or G12.
Old Sep 20, 2007 | 12:42 AM
auditech79's Avatar
Thats a hard one to answer, its right on the border line of which coolant to use. I would have the audi parts department run your VIN and see what it calls for.
If flushing the coolant doesn't fix your problem i would be looking for a leak by the thermostat housing.
eddiefury
Nov 9, 2008 07:34 AM
bkcox_S4
Jul 3, 2008 01:56 PM
Armenian
Jun 22, 2007 06:29 PM
a4anonymous
Sep 26, 2005 06:56 PM
skull10
Jan 16, 2005 01:04 PM
