Which Coolant to use??
Old Aug 24, 2005 | 08:29 PM
jimmysA4T's Avatar
Default Which Coolant to use??
Alright, I have already do some search in here but would need some assistance from you guys.
I drained the antifreez coolant from my A4 the other day and I was wondering which coolant
should I use. I'm sure the ones from the dealer is pretty expensive so I would like to take an
alternative route.
Is it ok for me to use Prestone's coolant fluid? I mean the red or orange kind? I know I don't
really like the green kind myself but I guess all coolant is suppose to do the same job. Please
let me know asap thanks!
Old Aug 24, 2005 | 08:40 PM
jlaudio184's Avatar
Default RE: Which Coolant to use??
get the real stuff from the dealer or ecstuning.com i wouldnt use anything but OEM, i think its Pentosin 11s, someone correct me if wrong
Old Aug 24, 2005 | 09:11 PM
CRAZYHAWK's Avatar
You meant G-12 antifreeze. You could also use universal yellow antifreeze. Flush the system first. You will always find this in an emergency.
Old Aug 24, 2005 | 09:18 PM
jlaudio184's Avatar
^^^ right
Old Aug 24, 2005 | 09:43 PM
Jestnomen's Avatar
6th Gear
One part distilled water to one part Pentosin G12 coolant.
Old Aug 25, 2005 | 01:37 PM
jimmysA4T's Avatar
Thanks again to you all for the advice
Old Aug 25, 2005 | 03:53 PM
brrman's Avatar
the Pentosin 11s is the power steering fluid. G-12 is what you should use for coolant.
Old Aug 25, 2005 | 03:56 PM
Karl's Avatar
yeah dont get those mixed up.. otherwise your going to be in a world of hurt.. but hey maybe your steering wheel would be cold!
Old Aug 26, 2005 | 12:23 PM
jimmysA4T's Avatar
Well, I went to check on the Prestone's orange coolant and it shows a G05 so
I suppose the car needs G12 that cost $10 more but I would think it's safer
to go with OEM as far as coolant.
Old Aug 26, 2005 | 12:29 PM
Jestnomen's Avatar
6th Gear
Well luckily you only have to change coolant every 2 years, so you really wouln't have been saving much money in the long run.
