Cooling issues
I was wondering if anyone new anything about the cooling systems and how they work in a 98 2.8Q, I know how they generally work, but I have no idea why I'm loosing coolant almost every 1000 miles. I think it is coming out of the over flow tank, out of a rear spout that is located underneath the cap(on the underside of the tank). What I think it is doing, it is getting to hot, then pouring out of there, and then every corner I turn the coolant light comes on. Recently, I put a hose on that open spout ( I don't know if there is a hose that is supposed to be there ), with a screw on the end plugging it. Just today, I turn a corner and the light returns. The only other thing that I was thinking was the thermostat. Which doesnt make sense if it was, mainly because the car is not over-heating(well not yet).
My main question to you is: Does the overflow tank have a factory problem with it, and/or what could be the problem?
Thanks a million if you know the problem or have had a similar problem but now is fixed. I'm a poor student that needs a cheap fix, and I know my old cars like the back of my hand, but I don't want to go to in depth on working on a newer german.
Thanks to any reply,
Poor college student With his first German
If the coolant is dissappearing then either it is leaking outside of the engine or into the engine.
Are there any visible leaks on the outside? Can you see coolant leaking under the car? Can you smell hot coolant? If so, locate the leak and replace the leaking part. The coolant overflow reservoir can develop a crack and leak.
Is the coolant leaking into the engine? Do you get white smoke when you start the car after sitting overnight?
check your oil? Does it look like cappuchino? If so you are leaking coolant into the oil.
If none of the above, then have a mechanic pressure check the engine and either use dye to help find the leak.
