Corner light question...
Old Apr 22, 2005 | 08:18 PM
azarlengo781's Avatar
Default Corner light question...
Hey, Im having a problem with my two piece lamps... The corner light plastic housing that covers the bulb keeps melting for some reason... this is my second pair of corners... I am upgrading to one piece valeos, but I am afraid that this will happen to the corners lights as well on those... I really can't afford for that to happen... Any suggestions??? Thanks... oh yeah and I am using normal yellow bulbs...
Old Apr 22, 2005 | 08:32 PM
BFlan2001's Avatar
Default RE: Corner light question...
you may have a short in your wiring harness...if you're not familiar with electrical systems you may want to take it into a shop...
Old Apr 22, 2005 | 08:37 PM
PandaXpress's Avatar
where u using after makeret sides or the OEM sides and what was the wattage of the bulbs
if there aftermarket sides some of them are crap and melt
Old Apr 22, 2005 | 11:01 PM
Jestnomen's Avatar
6th Gear
A short would blow the fuse. I would check the wattage of the bulbs. Probably want to replace them regardless.
luciddream42186
Jan 25, 2012 08:13 PM
1.8TNYC
Feb 9, 2010 03:18 PM
PluschakovP
Jan 20, 2009 09:51 PM
osterthetoaster
Feb 25, 2008 01:12 PM
jits1980
May 25, 2007 10:37 AM
