Cruise control problem
Old Jan 3, 2005 | 03:06 AM
PietB's Avatar
Default Cruise control problem
Hello,
I am new to this forum and have a question about my cruise control
I have a 2000 A4, when I bought the car (used) the cruise control resume/increase speed switch did not work properly, when the switch was activated the cruise control stopped. This happened occasionaly, however I noticed that when I started a trip the first 3 times the switch was activated it always workes, when it is used for more then 3 times the switch fails in about 1 of 2 times. The car was under guarantee so the switch was replaced. Now after 1,5 year exact the same problem occurs again.
My dealer tels me this is not a common problem and it's just my bad luck.
When my switch only last for 1,5 years there must be more people with this problem.
Does anyone know this problem ?
Old Jan 3, 2005 | 09:56 AM
Jestnomen's Avatar
6th Gear
Default RE: Cruise control problem
Faulty switches are a VERY common problem. Mine is messed up too! The dealer is full of it.
Old Jan 3, 2005 | 12:12 PM
CRAZYHAWK's Avatar
When you use the resume speed feature, you must go a little faster than the speed you want to resume.
Old Jan 3, 2005 | 02:00 PM
brrman's Avatar
My 2000 A4 has this problem constantly. My 1998.5 A5 had it intermittently.
It is very common and the dealer is either ignorant or BSing you.
Old Jan 3, 2005 | 07:54 PM
david9999's Avatar
Have you tried some contact cleaner?
Old Jan 4, 2005 | 04:46 PM
PietB's Avatar
It is good to know that this is not just bad luck.
Is it difficult to replace the switch, do I need special tools for this ?
Old Jan 4, 2005 | 04:52 PM
CRAZYHAWK's Avatar
Try spraying the switch with Radio Shack tuner cleaner.
Old Aug 25, 2006 | 12:12 AM
ruby's Avatar
where is the cruise control switch? the actual lever thing?
Old Aug 25, 2006 | 04:23 PM
Somnio's Avatar
My cruise controll does not operate as well. It's not bad luck, it's Audi.
Old Aug 25, 2006 | 04:44 PM
xbrian87's Avatar
+1 for the "My CC is Dead" boat!
(Mine's dead, too!)
