Cylinder #1 Misfire
Old Apr 27, 2006 | 04:22 PM
A4 the Quattro's Avatar
Default Cylinder #1 Misfire
i have been having problems with my car lately... its been surging a little under boost.. well last night i threw a CEL... checked the code this morning and i had a #1 Cylinder Misfire .. if you guys remember this is the cylinder i had with a little bit of oil in it.. could the oil have ruined the plug??
im hoping that its only the spark plugs that are bad... anyone think the coilpack could cause this? i know lots of people have had problems with their coilpacks..
searched and found everyone likes to run the NGK BKR6E .... same plug i ran in the MR2 Turbo... ill get some plugs on order today.. so i can see wtf is up with the black beast..
p.s. compression in #1 Cylinder was 200 .. incase anyone asks..
Old Apr 27, 2006 | 04:31 PM
aRIf's Avatar
Default RE: Cylinder #1 Misfire
no need to order, you can get it local and try is asap.
Old Apr 27, 2006 | 04:36 PM
ya well the local shop here usually doesnt stock the BKR6E atleast they didnt used to.. ill check it out here in a few..
Old Apr 27, 2006 | 04:53 PM
techbod's Avatar
NGK BKR6E ...??
correct plug = BKUR6ET-10
others are Bosch F7LTCR
AUTOLITE APP3923
BERU 14FGH-7DTURX
CHAMPION RC89TMC
Old Apr 27, 2006 | 05:01 PM
techbod's Avatar
misfire things to check = plug lead for arcing if its a coil pack type lead then it could the the rubber part that connects to the plug they do fail and hard to tell "change it", other is the oil which is a concern "it builds up round the plug and causes a short "change the rocker cover gasket"
Old Apr 27, 2006 | 05:26 PM
north5995's Avatar
ORIGINAL: avant80@2.6
NGK BKR6E ...??
AUTOLITE APP3923
BERU 14FGH-7DTURX
CHAMPION RC89TMC
Is there a definate answer from GIAC about what plugs they recommend? Because when I was reading the gazillion threads about spark plugs, everyone seemed to run NGK BKR6E or various others.
Old Apr 27, 2006 | 05:40 PM
techbod's Avatar
when doing an upgrade the plugs should be selected for that tuneup or the gaps set "dependant on plug type", the above information is for the standard 1.8T, I would look to greater spec plugs for performance reasons I only quote manufacturers spec
Old Apr 27, 2006 | 09:01 PM
well i just put in some BKR6E gapped at about .030
so far car is running great!!
Russ Heinrichs
Aug 18, 2021 12:39 PM
and b
Feb 10, 2014 11:52 AM
ThePizza
Jul 23, 2008 05:16 PM
ricky0323
Feb 29, 2008 01:35 PM
