Cylinder Misfire
Hello all, I have a 2002 A4 3.0 V6 Quattro and Friday evening I had a cylinder begin to misfire. I scanned it and it is cylinder 4. I have searched through the forum and it seems this is probably a coil, ICU, or bad plug. The car is stock and has 46,000 miles on it. I would like to trouble shoot it by switching coils and what not to narrow it down and see if the code changes, could someone provide some instructions on how to do this; pictures would be great.
Thanks.
Joe
Thanks.
Joe
Note[/align]
Press pencil-type ignition coils into the openings provided on the cylinder head cover by hand.
6-cyl. 3.0 ltr. and 3.2 ltr. FSI engines
Switch off ignition.
Remove engine cover panel (if fitted).
Cylinder bank (right-side)
Remove upper section of air cleaner
Remove both bolts -1-.
Push connector -2- towards pencil-type ignition coil, press catch down by hand and pull off connector.
Use puller -T40039- to detach pencil-type ignition coils -3- from spark plugs.
Remove spark plugs using spark plug socket -T40039-.
Install new spark plugs.
Tightening torques
Nm
Spark plugs in cylinder head
30
Note[/align]
Cylinder bank (left-side)
Remove coolant expansion tank -arrow -.
Tie coolant expansion tank to one side with coolant hoses -1...3- attached.
Tightening torques
Nm
30
[IMG]local://upfiles/12092/15431226D02B4EACBC8B017A5E6BE6CA.jpg[/IMG]
[IMG]local://upfiles/12092/74B4A7F186B84304B980B70495F7D162.jpg[/IMG]
[IMG]local://upfiles/12092/84EB23C5CFDE486482F03926668E5FD0.jpg[/IMG]
Russ Heinrichs
Aug 18, 2021 12:39 PM
A4ENGRSF
Oct 9, 2010 09:49 PM
