Cylinder2 miss fire
Old Aug 13, 2007 | 06:16 PM
JustinAudi's Avatar
Default Cylinder2 miss fire
Yesterday my car engine started running really rough and the ce light started flashing. I pulled the codes and got that cylinder 2 was missfireing. I believe that i have ruled out the coil pack and the spark plugs by swapping them with cylinder 3. I don't know what else it can be any suggestions?? Thank you
Oh and the car is 97' A4 1.8t Q
Old Aug 13, 2007 | 06:33 PM
cincyTT's Avatar
I'm make believe
Default RE: Cylinder2 miss fire
Ifit still said miss fire in cyl 2, check your coilpack harness to look for damage.
Old Aug 13, 2007 | 06:40 PM
JustinAudi's Avatar
Check the harness and could not see anything wrong to my knowledge
Old Aug 13, 2007 | 08:10 PM
david9999's Avatar
Cyl 2 misfire that doesn't move with plugs or coil change is likely the ignition control module.
Old Aug 16, 2007 | 02:39 PM
premierdetail's Avatar
hey i had the same exact thing happen to mine, after i wasted money on a new coil pack i found out it was exactly what david is telling you the ingition control module...definately try that first it fixed mine rt up and only took about 10 min to change!
Old Aug 16, 2007 | 04:44 PM
Lazer Viking's Avatar
ORIGINAL: david9999
ding, missfire on #2 is almost always the icm
rajien2
Apr 16, 2015 10:37 PM
wesley7883
Jul 18, 2014 08:00 PM
06A42.0TUt
Dec 14, 2012 06:42 PM
onepoint8tee
Dec 13, 2006 10:33 PM
hugoagogo
Sep 9, 2006 10:38 AM
