debadge marks
So when I debadged my A4, there was some wax buildup left, and it looked really apparent. I went to Schucks and asked if they had any compound that could blend the waxed and non-waxed area together so the grooves wouldn't be so apparent, but like usual, all I got was "uhh... well I'm not too sure about that... but you could try this...."
I ended up not buying anything, because they're fucking retards and can never make any legit suggestions. So what product do you guys recommend? |
RE: debadge marks
buffing is the best solution. maybe claybar can take it out a bit too
RE: debadge marks
I would keep re-applying goo gone, and keep with the hair dryer. It takes awhile, but eventually after some hard rubbing, and a bunch of washes, it should look good.
RE: debadge marks
Use Clay bar wax or a scratch remover from Miguiers. does two will work best. after you aply it on let it sit for a while until its dry then rub it off by putting presure. the scratch remover costs like 7 bucks.
RE: debadge marks
ORIGINAL: AudiRider818 Use Clay bar wax or a scratch remover from Miguiers. does two will work best. after you aply it on let it sit for a while until its dry then rub it off by putting presure. the scratch remover costs like 7 bucks. |
RE: debadge marks
ORIGINAL: Bogie ORIGINAL: AudiRider818 Use Clay bar wax or a scratch remover from Miguiers. does two will work best. after you aply it on let it sit for a while until its dry then rub it off by putting presure. the scratch remover costs like 7 bucks. |
