debadge marks
Old Nov 30, 2007 | 06:14 PM
Leifer's Avatar
Default debadge marks
So when I debadged my A4, there was some wax buildup left, and it looked really apparent. I went to Schucks and asked if they had any compound that could blend the waxed and non-waxed area together so the grooves wouldn't be so apparent, but like usual, all I got was "uhh... well I'm not too sure about that... but you could try this...."
I ended up not buying anything, because they're ******* retards and can never make any legit suggestions. So what product do you guys recommend?
Old Nov 30, 2007 | 06:40 PM
hiwords's Avatar
Default RE: debadge marks
buffing is the best solution. maybe claybar can take it out a bit too
Old Nov 30, 2007 | 08:29 PM
01A4T's Avatar
I would keep re-applying goo gone, and keep with the hair dryer. It takes awhile, but eventually after some hard rubbing, and a bunch of washes, it should look good.
Old Nov 30, 2007 | 08:47 PM
AudiRider818's Avatar
Member
Use Clay bar wax or a scratch remover from Miguiers. does two will work best. after you aply it on let it sit for a while until its dry then rub it off by putting presure. the scratch remover costs like 7 bucks.
Old Nov 30, 2007 | 09:15 PM
Bogie's Avatar
ORIGINAL: AudiRider818
I'm going to need the Urban Dictionary to understand you. http://www.amazon.com/Urban-Dictiona.../dp/0740751433
Old Nov 30, 2007 | 09:21 PM
01A4T's Avatar
ORIGINAL: Bogie
Man, give him a break.....He could be 5 years old or somthing.
gtg33k
Aug 9, 2015 09:49 PM
Swaynest
Aug 14, 2008 03:59 PM
skindiggler
Sep 28, 2007 12:32 PM
Audi A Fizzle
Jun 12, 2007 09:01 PM
VB05
Jul 20, 2005 04:28 PM
