debadged but..
Old Jul 6, 2006 | 02:14 AM
juice88's Avatar
Default debadged but..
well i just debadged the a4 badge to see how that looks and i was then going to decide if i want to take off the 1.8t. well i did the debadge but if u get close, u can see an outline of the A and 4. idk what to do to get this off...help!!!
BTW- i followed the write up on here for the diy and i repeated the process of heating the area then applying the goo remover then rubbing. maybe im doing something wrong
Old Jul 6, 2006 | 02:48 AM
VB05's Avatar
Default RE: debadged but..
ORIGINAL: juice88
it won't all come out right away, you can also use some compound with a buffer wheel (if you have one). it goes away eventually
Old Jul 6, 2006 | 02:51 AM
dan's Avatar
dan
could also try something like scratchx by hand, it should help a lil
Old Jul 6, 2006 | 02:53 AM
VB05's Avatar
yea, there is alot of stuff out there...i used this stuff called "Oops!" that worked pretty well. You're gonna see a little outline no matter what, but it fades.
Old Jul 6, 2006 | 03:15 AM
ejc317's Avatar
use paint cleaner and then polish then wax
it comes off rigth away
Old Jul 6, 2006 | 04:05 AM
endle55's Avatar
DO NOT U PAINT CLEANER, ALCOHOL, PAINT THINNER OR ANY CLEANING SOLVENT
It will eat away at your clear coat paint, and cause your paint to fade and dull away, in extreme cases rust.
Just get some fine grit polish and polish it out.
Old Jul 6, 2006 | 04:53 AM
ejc317's Avatar
errrr i meant paint cleaner as in the mcguire's paint cleaner ... not thinner
Old Jul 6, 2006 | 10:43 AM
smokeU's Avatar
use some good ol fashion elbow grease!
CrazyBignate
Jan 29, 2014 12:15 PM
SilverA4q
Aug 27, 2007 02:47 AM
BlkQ
Apr 25, 2007 09:19 PM
Russ03A4
Mar 15, 2006 04:05 PM
StepUpProductions
Jan 12, 2006 04:09 AM
