RE: Diesel in Oil to clean it out!!!! IT WORKS!!!!
i used to run 0-w40 and i never had any problem with it
i wonder why jeff, cause its an approved oil? ;)
ORIGINAL: cincyTT i wonder why jeff, cause its an approved oil? ;) lol thats awesome. |
Using diesel fuel or kerosene for flushing engines crankcase has been around for years. Most don't drive it while its in there though. Pour a quart in and idle the engine for 10 minutes and then take out the plug and filter and let her drain real good. It works well. And before Seafoam was around we used to do that with type A transmission fluid.
ORIGINAL: Redrum1 Using diesel fuel or kerosene for flushing engines crankcase has been around for years. Most don't drive it while its in there though. Pour a quart in and idle the engine for 10 minutes and then take out the plug and filter and let her drain real good. It works well. And before Seafoam was around we used to do that with type A transmission fluid. Pull the plugs Turn it over a few times and drain and flush, rinse and repeat ;) After 4 or five flushes, the diesel should come out pretty clear Let the car sit for an hour or 2 with the drain plug and oil filler cap off so any excess diesel can evaporate and leave the system. Fill the engine with oil again and take it for a drive using the old filter. Drain oil one last time and then put in your Royal purple or whatever the hell it is you put in there to run the car regularly. This should be thorough enough. I NEVER ran the car though, I think that's asking for trouble |
