Diode mod+hpbc question
Old Jan 14, 2008 | 01:33 AM
B5 owns's Avatar
Default Diode mod+hpbc question
If I do the diode mod and run a turboxs hpbc while bypassing the n75, can I just turn the psi back down to 9psi whenever I wanted to? Would I still get a benefit like holding boost longer?
Old Jan 14, 2008 | 01:39 AM
cincyTT's Avatar
I'm make believe
Default RE: Diode mod+hpbc question
if you use the hpbc, you dont want to use the n75, that is the entire reason TO buy a hpbc. The hpbc is smooth and doesnt require use of the n75. Plus you want one boost controller if at all possible. If you bypass, you will be able to no problem, if you for some reason run it inline, then the lowest you could probably run is 10-11psi since it will still bleed of some boost.
Old Jan 14, 2008 | 03:36 AM
B5 owns's Avatar
I said im gonna bypass it. Im not going to be using the n75, im just asking if I can lower the psi on my hpbc back down to 9psi and If i will still be getting a benefit.
Also, there are 3 hoses going to the n75, so which hoses do I connect to the hpbc and what do I do with the left over hose?
Old Jan 14, 2008 | 08:13 AM
chaos92287's Avatar
there should only be 2 hoses on the n75, with the third end of the n75 plugged into the TIP. For the MBC, the side end goes to the wastegate and the bottom end to the banjo bolt, and plug the hole on the TIP.
Old Jan 14, 2008 | 12:32 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: B5 owns
sorry, i was getting sleepy. The wastegate is set to 5psi and you can turn the boost to anything above that with the n75 bypassed
Old Jan 14, 2008 | 01:41 PM
B5 owns's Avatar
Great, thanks alot!
arturttq
May 26, 2010 11:44 PM
blackphoenix
Jun 27, 2008 09:58 PM
Ergokinetics
Apr 26, 2008 06:09 PM
chosos
Mar 22, 2008 03:30 PM
discontained
Jul 5, 2007 03:33 PM
