Dipped headlight?
Old Sep 11, 2005 | 08:26 PM
blka4man's Avatar
Default Dipped headlight?
This my second dipped headlight. First was right, now the left. I took my car into the dealer to fix the first time and only took about 5 min. Just wondering if there is someting that I can do to fix the left side on my own. Also please tell me what dipped headlight means. Thanks
Old Sep 11, 2005 | 11:23 PM
david9999's Avatar
Default RE: Dipped headlight?
Driver's side light is supposed to be dipped a bit compared to passenger. This keeps it from blinding oncoming traffic
Old Sep 12, 2005 | 04:16 AM
blka4man's Avatar
Sorry not to make this clearer, but I have a warning that pops up at startup that says that I have a dipped headlight. My headlight is completely out.
Old Sep 12, 2005 | 09:19 AM
david9999's Avatar
Is it just the low beam? If so you either have a burned out bulb or a loose connection, likely the former.
If neither high or low beam work, you have a wiring problem.
Old Sep 13, 2005 | 03:55 AM
blka4man's Avatar
Its just the low beam
Old Sep 13, 2005 | 08:50 AM
david9999's Avatar
Replace the burned out bulb.
Old Sep 13, 2005 | 10:15 AM
docurley's Avatar
What prob happened is that the person who changed them before did not us a clean cloth (prob only used there fingers) and the element burnt out as you must not handle the element.
Just buy a bulb and replace it, its not to hard at all.
Old Sep 14, 2005 | 12:15 AM
david9999's Avatar
Seeing as both the right and left bulb are on simultaneously, they tend to burn out close to the same time.
climber60614
Oct 2, 2013 11:42 AM
ArnaldoDC5
Jun 2, 2013 01:02 PM
Jrmiller
Feb 25, 2013 03:03 PM
ee99ee
Oct 25, 2010 11:10 PM
sandiegocanuck
May 24, 2007 04:09 PM
