disabling headlight washers
Well it has come to a point here here I'm going to disable my headlight washers. What all do I need to do besides plug the line leading to the washers?
I have a new bumper without the washer holes but I really won't miss them. Thanks again |
RE: disbaling headlight washers
I would think if you un plug them then you would be good to go.........
yea, those things are retarted, you could probably unplug it, and take out the squirter things while the bumper is off
I would just remove everything from the pump. There are two seperate pumps, one for your headlight washers and one for the windshield washers. Take the pump out and put a cork or something into the hole that is left in the resevoir and toss the hoses and washer units/nozels cuz you wont need them again... Or try to sell them maybe.
Why not spend 50 dollars and replace the pump.
ORIGINAL: david9999 Why not spend 50 dollars and replace the pump. I have a new bumper without the washer holes but I really won't miss them. |
I just folded my hose over like 3 times and used a hose clamp on it. Ghetto I know. but it works.
ORIGINAL: onepoint8tee ORIGINAL: david9999 Why not spend 50 dollars and replace the pump. I have a new bumper without the washer holes but I really won't miss them. |
I think I'll take out the pump and take the hose and melt the end so its closed, then fold it over a few times and clamp it.
Thanks guys! |
I need the driver side washer. I'll buy from you!\My is 2001 will it fit?
