disabling headlight washers
Old Nov 8, 2006 | 12:40 AM
wood_e's Avatar
Default disabling headlight washers
Well it has come to a point here here I'm going to disable my headlight washers. What all do I need to do besides plug the line leading to the washers?
I have a new bumper without the washer holes but I really won't miss them.
Thanks again
Old Nov 8, 2006 | 12:47 AM
Beer Mod's Avatar
Default RE: disbaling headlight washers
I would think if you un plug them then you would be good to go.........
Old Nov 8, 2006 | 12:48 AM
Lazer Viking's Avatar
yea, those things are retarted, you could probably unplug it, and take out the squirter things while the bumper is off
Old Nov 8, 2006 | 12:53 AM
onepoint8tee's Avatar
I would just remove everything from the pump. There are two seperate pumps, one for your headlight washers and one for the windshield washers. Take the pump out and put a cork or something into the hole that is left in the resevoir and toss the hoses and washer units/nozels cuz you wont need them again... Or try to sell them maybe.
Old Nov 8, 2006 | 09:42 AM
david9999's Avatar
Why not spend 50 dollars and replace the pump.
Old Nov 8, 2006 | 01:04 PM
ORIGINAL: david9999
Because hes not asking about a broken pump:
Old Nov 8, 2006 | 01:44 PM
The Bishop's Avatar
I just folded my hose over like 3 times and used a hose clamp on it. Ghetto I know. but it works.
Old Nov 8, 2006 | 01:57 PM
wood_e's Avatar
ORIGINAL: onepoint8tee
ORIGINAL: david9999
checkmate!
Old Nov 8, 2006 | 02:02 PM
wood_e's Avatar
I think I'll take out the pump and take the hose and melt the end so its closed, then fold it over a few times and clamp it.
Thanks guys!
Old Nov 8, 2006 | 09:16 PM
fcanozo's Avatar
I need the driver side washer. I'll buy from you!\My is 2001 will it fit?
