Diverter vavle
Old Dec 10, 2006 | 08:14 PM
JohnnyBravoA4's Avatar
Default Diverter vavle
i have a 007 DV, its a little beat up, think i may have put to much grease in it, or its just all worn, i tried changing the springs but it made everything worse, seems to misfire now when im a WOT everything is fine till it gets to about 19-21 psi then it feels like a back-fire.. should I just put the other spring back in or should I buy a new DV, and which one should I go with? keep in mind its a big turbo so i dont know what would be best.. thanks
Old Dec 10, 2006 | 08:17 PM
Beer Mod's Avatar
Default RE: Diverter vavle
If a spring change made it worse then atleast you know it's partly the DV. Maybe borrow someone elses DV, any friends close by?
Old Dec 10, 2006 | 08:22 PM
plenty of friends, no one with a audi.. yea it was fine for like 30 minutes then it started acting up it would hold 21psi and now the boost jumps all over the place and the car makes a poping noise like a misfire. so I just asume its the DV because i didnt change anything else, i was only holding 18 before and it was fine.
what DV should I buy? i had an evo dv in my last car but it was not tunable, dont really know if its worth it, alot of people run the baileys
Old Dec 10, 2006 | 08:44 PM
BadLuckAudi's Avatar
baileys and forge are the best
Old Dec 10, 2006 | 11:26 PM
well my forge is beat but i do have the spring kit for it so maybe ill just buy a new one
Old Dec 12, 2006 | 07:05 PM
SpeedTL's Avatar
I found these articles on the net: http://www.s4biturbo.com/art-dvtests.php & http://www.s4biturbo.com/art-dvtests2.php The Bosch ones might be more reliable.
Old Dec 12, 2006 | 07:50 PM
GTOrleans's Avatar
bosch are used on TT's now, if he has a big turbo hell need something a little stronger, plus i don't think they are tunable.
Old Dec 12, 2006 | 07:54 PM
phil872001's Avatar
Johnny is running a GT28RS i believe, correct me if i'm wrong.
Old Dec 12, 2006 | 08:47 PM
Ford2Audi6's Avatar
Make sure you have the right color spring, I have a spring set for a forge 007. PM if you want one.
xxipsxx
12
Feb 20, 2011 09:28 AM
macspeed702
Feb 23, 2008 07:10 PM
EliteTuning1
Sep 12, 2006 06:34 PM
Sp33d07
Jul 19, 2006 07:39 AM
Sp33d07
May 22, 2006 10:45 PM
