DIY Fuel pressure Regulator?
Old Sep 23, 2007 | 01:03 PM
Audi_Skydiver's Avatar
Default DIY Fuel pressure Regulator?
Anyone know of a DIY for a fuel pressure regulator? I searched around and didn't find anything. It looks simple enough to do but just wondering. Also where does the fuel pressure gauge go? And on the 034 motorsports AFPR how do you adjust it? It looks like you do it from the top but I am not sure. Thanks!
josh
Old Sep 23, 2007 | 01:08 PM
EVOLA4's Avatar
Default RE: DIY Fuel pressure Regulator?
+1 good question. I'd like to know this as well
Old Sep 23, 2007 | 01:10 PM
hiwords's Avatar
wel u got 2 choices, the feed line or return line so just flip a coin lol j/k i would like to kno too
Old Sep 23, 2007 | 01:26 PM
No one has ever installed one of these?
Josh
Old Sep 23, 2007 | 01:37 PM
hiwords's Avatar
i think the pressure regulator u depressurize the system then remove the old regulator. but that's just me babbling and hoping lol
Old Sep 23, 2007 | 01:40 PM
Yeah I figured you would need to do that but I guess the main question I have is where to put the gauge to get a correct reading and how to actually adjust the fuel pressure.
josh
Old Sep 23, 2007 | 01:45 PM
cincyTT's Avatar
I'm make believe
i have done it a few times. You might want to depressurize the system otherwise the reinstall is a bitch. So start the car and then pull the fuel pump fuse andlet it run out of gas. Then you just pull the clip, place a towel around the bottom to catchany fueland then pull it up and out. Then jsut reverse, push it in and then get the clip back in (easier said then done). You should install the gauge while you have low fuel pressure in the system. All you have to do for that is cut the fuel feed line before the fuel rail and then slide in the gauge and tighten down the clamps. Again a towel to catch any fuel
Old Sep 23, 2007 | 01:48 PM
hiwords's Avatar
the thought of cutting sumthing like that makes my pants wet lol
Old Sep 23, 2007 | 01:50 PM
cincyTT's Avatar
I'm make believe
LOL, its going to get filled and its far easier than you think
Old Sep 23, 2007 | 02:14 PM
Sweet. So I want to cut this line to place the gauge in?
Josh
