which do you prefer ? buffing by hand or with a electric buffer?
Old Aug 12, 2005 | 01:07 PM
brent07's Avatar
Default which do you prefer ? buffing by hand or with a electric buffer?
i personaly have only put on wax and buffed ect. by hand. i havent spend the 20 dollars to put into a cheap buffer at the local car shop. i am curious to see if those electric buffers really are that much better for applying and buffing the wax ? what do you think ?
Old Aug 12, 2005 | 01:13 PM
clconversion's Avatar
Default RE: which do you prefer ? buffing by hand or with a electric buffer?
the $20 electric ones are not worth the money definetly not powerful enough much rather do it by hand
Old Aug 12, 2005 | 02:58 PM
brrman's Avatar
Electric buffer is definitely easier, but by hand usually gives better results (unless you know what you are doing and use a PorterCable or something). I use a crappy $20 buffer to put wax on the car, but use my hands for removing the wax, and rubbing compound and glazing.
Old Aug 12, 2005 | 07:02 PM
apg96's Avatar
i do the same as brrman. use it to put it on soley on the fact that its faster and easier to do it. If u get a good buffer (lik ethe one meguiers sells) and u know what ur doing then u will end up get better results.
Old Aug 12, 2005 | 07:09 PM
PandaXpress's Avatar
cheap buffers suck when removing wax i remove it by hand
Old Aug 12, 2005 | 07:54 PM
david9999's Avatar
I prefer my girlfriend to my hand.
Old Aug 12, 2005 | 08:22 PM
brent07's Avatar
haha yeah ... i know what you mean man .... alright i think its gonna be done all by hand .. the good'ol fashion way .. get to know you car better this way .... thanks guys saved me 20 bucks haha
Old Aug 14, 2005 | 06:48 AM
luvin_the_rings's Avatar
the only thing i noticed is that the buffers give you buff lines, little shiny lines when the sun hits it right
but i was much happier when i went over the paint again with a dry rag in hand to get that off the best i could
Old Aug 14, 2005 | 07:15 AM
Karl's Avatar
the swirl marks you are referring to can be caused by using the wrong type of applicator.. you should really look into a quality pad that is super soft..
Old Aug 16, 2005 | 02:44 AM
GTMA4's Avatar
I use meguiars 3 step polish kit. Its a pain, but when you finish it shines like no other, and your hand just runs so smoothly over the car
