done with the timing belt, but...
Old Oct 4, 2007 | 06:09 PM
dmichael's Avatar
Default done with the timing belt, but...
I had a quick question to ask. I just put the front end of my car back together after doing a timing belt, water pump and such on my 2001 A4 1.8t. Well it’s all about back together now and something finally struck me as being a little strange. I put the belt on and it looked and felt like all the belt teeth lined up (extremely hard to put on) but when I turned the crank by hand (lots of resistance) every ¼ turn of the crank I heard a clicking noise (like two metal parts contacting each other) that only seemed to happen four times on a full rotation of the crank. I just wanted to know if anyone knows what this issue could be before I start the car or if it is even anything I should mind. I have heard the stories about the valves and such going horribly wrong.
Old Oct 4, 2007 | 06:26 PM
widgget's Avatar
Default RE: done with the timing belt, but...
i don't remember a clicking on mine when i turned the crank. did you use a punch and mark the pulleys? you might want to verify that they are still lined up correctly.
Old Oct 4, 2007 | 06:28 PM
Lazer Viking's Avatar
did you put the belt on in the correct position...
Old Oct 4, 2007 | 06:30 PM
dmichael's Avatar
i marked the top gear and the bottom one, both did not move when i put the new belt on. i also had somone looking at the top gear to make sure. i just done know what that could be.
Old Oct 4, 2007 | 06:41 PM
dmichael's Avatar
here is a pic of how it looked right before i took it off and this is just how i put it on, i did not move both pullys, kept them just the same way as it was when i turned the car off.
Old Oct 4, 2007 | 07:41 PM
dmichael's Avatar
No ideas before i start the car? i guess it really does not matter what is said if im going to start it anyways.
Old Oct 4, 2007 | 07:52 PM
01afour's Avatar
how was changing the timing belt anyway?? is it just like most cars or is more complicated?? cause i think im gunna have to do mine soon. i hear a clicking that sounds like the timing is off a little.
Old Oct 4, 2007 | 09:52 PM
99A4NOW's Avatar
I wouldn't start it if I were you. Wouldn't you think that is the piston contacting a valve, four click- four pistons- two intake valves and two exhaust valves. $1500 worth of head work would make it worth taking apart again and checking everything.
Can you tell where the clicking is comming from?
Old Oct 4, 2007 | 09:59 PM
CLX's Avatar
CLX
Zombie Defense Force
ORIGINAL: 99A4NOW
Three intake and two exhast. 5v ftw!
Old Oct 4, 2007 | 10:13 PM
dmichael's Avatar
yeah so i started the car, it seemed ok but i still have a CEL from the cam position sensor, do i have to clear that? well here is a vid on youtube on the car when i started it, tell me if this is all normal,and if something would have happened would it have gone wrong by now? http://www.youtube.com/watch?v=siirVtRn1x0
