dont know if this is normal, or I have a boost leak???
Old Jul 10, 2006 | 01:48 AM
JohnnyBravoA4's Avatar
Default dont know if this is normal, or I have a boost leak???
ok i have a 99 1.8t with the non pc 16 giac ko4 file, just put in the n75 H looped in with a MBC, when i first got just the N75 H in i would hold 16psi till red line and would spike at like 23 but i had really bad surging so i looped in the MBC when i did that it would go to about 19 then drop to 15-16 till red line and in 5th gear i would get some boost creep, I have been changing the MBC to different settings and it always seams to fall back but now ill build about 19-21psi then it drops to around 14 till red line in first gear it seams to drop more I just wanted to know if this was normal or if i should start looking for a boost leak.. will be putting in a fmic soon with injectors so i can get the pc 16 file.. but i want to get this all sorted out first.. any help would be great..
Old Jul 10, 2006 | 01:08 PM
Default RE: dont know if this is normal, or I have a boost leak???
anyone??
Old Jul 10, 2006 | 01:36 PM
onepoint8tee's Avatar
Id get the correct K04 software for your k04 and go from there.
Old Jul 10, 2006 | 01:42 PM
i do have the right software, its the non pc16 ko4 file that giac makes, it just blows in my opinion
Old Jul 10, 2006 | 01:59 PM
ORIGINAL: JohnnyBravoA4
Oh... Well.... I think they made the pc16 file for a reason, maybe thats it. You have a 710N dv?? Maybe its going bad??
Old Jul 10, 2006 | 02:03 PM
no i have an evo dv
Old Jul 10, 2006 | 02:09 PM
Id take it out and inspect it just to make sure its working right, or make a boost leak tester. I think there is a DIY for one on Audiworld or if you search there was a thread on how someone built one a while back. Also, take out your MBC and just use the n75 and see what happens just for troubleshooting.
Old Jul 10, 2006 | 02:13 PM
blah.. this stuff sucks why cant the car just run right all the time.. i would say its a temperature thing because i know when its hot out that i get lower boost but i ran the car last night and it was 70 out and really cool, ran into the same problem.. ill look at the dIY boost leak and run a buch of test with and with out the MBC but its all in such a tight spot and i have rather large hands its always a pain to take crap like that off.
Old Jul 10, 2006 | 02:17 PM
BaconBait's Avatar
Have you scanned it for codes yet?
Old Jul 10, 2006 | 02:18 PM
yea no codes
Dri2.7T
Apr 2, 2012 01:58 AM
Newaudiguy99.5
Sep 3, 2011 01:46 PM
thareals4
May 19, 2008 03:34 PM
luu
May 1, 2006 11:31 AM
