door lock actuator leaks?
Old Sep 29, 2010 | 11:38 PM
oldgearhead's Avatar
Default door lock actuator leaks?
I've got a code for the central lock pump running too long. I can hear a vacuum leak around the drivers door lock. I pulled the door panel off to look for a broken hose, but everything looks intact. I guess the lock actuator itself is leaking. Does anybody know if this is common? Is this a dealer only part? The lock works, but I can hear the air leak when it locks. I don't hear any leak when it unlocks. The passenger side doesn't make the same noise, so I'm pretty sure the drivers door lock is the culprit. All I see in my searches is problems with the pump, but I think mine is OK.
Angrywasp
Mar 26, 2011 08:45 PM
newzboys
Feb 11, 2011 10:08 PM
oldgearhead
Sep 30, 2010 12:39 PM
nypapaya
Aug 2, 2010 10:45 PM
kd7wrc
Oct 3, 2004 05:18 AM
