Door Lock motor replacement
Old Feb 3, 2005 | 12:20 PM
jb642's Avatar
Default Door Lock motor replacement
Has anyone replaced the door lock motor (actuator) ? I have a 1998 A4 Quattro and the doors/truck will not unlock electrically (they do lock though). Dealer says I need a new "door lock motor" and can fix the problem for $700.00 !! Thanks for your help.
Old Feb 3, 2005 | 07:04 PM
Jestnomen's Avatar
6th Gear
Default RE: Door Lock motor replacement
Hi jb642, welcome to the forum. It can't be that bad to replace yourself. If you are feeling ambitious let us know.
Old Feb 4, 2005 | 01:28 AM
jb642's Avatar
Thanks for the Welcome! I'm very glad to find your forum!
I will do the replacement myself - the problem is finding a replacement motor - any ideas? Thanks!
Old Feb 4, 2005 | 02:09 AM
Jestnomen's Avatar
6th Gear
Sure!
http://www.car-part.com. Find a used one for cheaper. If you want I can get you a part number if you want to buy it new from an online dealer. Let me know.
Old Feb 4, 2005 | 06:37 PM
jb642's Avatar
Thanks Jestnomen -
I fould the part, new, for $175 on their web site. Do you know where the pump is located?
Sure is a lot cheaper to put in myself instead of paying dealer $700!!!!
Old Feb 4, 2005 | 07:25 PM
Jestnomen's Avatar
6th Gear
what's the part number you found? I'll post a diagram with it.
Old Feb 4, 2005 | 07:45 PM
jb642's Avatar
Here are the results from car-part.com - not sure if the Audi part number is "hiding" in their info (no numbers in common from the 3 companies):
1998 Vacuum Pump Audi A4 - DOOR LOCK VAC PUMP 8L0 862 257B 000913 $175 Dads Auto Parts USA-CA(Sacremento)
1998 Vacuum Pump Audi A4 PWR LK PUMP 4DR SED 288, 417.00 NEW I-048 $150 Harbor Auto Used Part Division USA-MA(Lynn)
1998 Vacuum Pump Audi A4 VAC PUMP FOR LOCKS, I008 230997 B D021 $100 Nik's Auto Parts, Inc. RP+ Member USA-WI(Neenah)
Thanks again
Old Feb 5, 2005 | 02:24 AM
Jestnomen's Avatar
6th Gear
Here's what I show...
I have military duty all weekend, but can answer your questions on sunday night when I return.
Old Feb 7, 2005 | 02:04 PM
jb642's Avatar
Thanks for the diagram - looks like it is located on the right side in the trunk - Do you know where I can order a new pump versus a used one? Thanks again for your help and diagram!! JB
ps: Which service are you in ? and thanks for serving !!!
Old Feb 7, 2005 | 02:07 PM
Jestnomen's Avatar
6th Gear
try http://www.impexfap.com or http://www.clairparts.com. The later one you will have to call for a quote. I'm in the Air Force.
