DOOR SEAL TEST
Old Oct 25, 2005 | 08:03 PM
BLAZEDUPBEE's Avatar
Default DOOR SEAL TEST
How can i determine if the seals to my doors are F-up. cause like my previous post about im drowning.. i Still am and now its getting worse. i just got about a inch of NOREASTER STORM water behind my driver side seat. I need to get this resolved ASAP i dont wanna mess up anything electrical.. THANKS
Old Oct 25, 2005 | 08:14 PM
juandango's Avatar
Default RE: DOOR SEAL TEST
I have a similar problem , (see my post).
Have a look at this website http://www.audipages.com/Tech_Articl...tordrains.html
. although it does relate to an A8, but all I could find, may be relevant.
..see the part which is titled 'Checking the Engine Compartment Drains'.
Old Oct 25, 2005 | 08:31 PM
FezA4's Avatar
Seems childish but just spray the seals on your doors with a hose and see if anything gets wet... just a thought. Do you have a moonroof? I've heard of the water seeping in there and dripping down the A-Pillar... no sure how hard of a fix this is but im sure one of the older members has a link.... I'd recommend doing a search.. plenty of people have had this problem in the past.
Old Oct 25, 2005 | 10:28 PM
VitaminB6's Avatar
What I've found works well is the following - take a sheet of fairly heavy 8.5 x 11 paper (like what you would use on a laser printer, not from a pad of writing paper), close the door on it, and see if you can pull it out without tearing it. If you can, then your seals can let in heavy rainfall, or water splashed when driving through a puddle.
Old Oct 26, 2005 | 01:30 PM
thanks alot JUANDANGO.. ima see if that works. did it help out for you at all? im going to do that this weekend. ive gotten alot of water behind the driver seat.
Old Oct 26, 2005 | 11:33 PM
juandango's Avatar
yeah mine was the drain under the battery . A/C would be front flooding I can guess. the sunroof drains maybe or door seals .
get a hose pipe on it or go through a car wash checking for possible leaks maybe.
ManyAudis
Nov 8, 2013 02:12 PM
2012A4
B8 Models
Nov 27, 2012 10:11 PM
FDEVITA
Jun 21, 2011 11:25 PM
bosnianac
Sep 6, 2007 12:09 PM
QuattroChucko
Apr 4, 2007 02:57 AM
