Double-Din Bezel for A4 B6?
I have a 2004 Audi A4 with the Symphony head unit (single din). Under that is the adjustment for temp and then under that is the 2 buttons for defrost, etc. Under that I have an empty area where you can throw junk.
SO......
I am thinking of getting the Pioneer AVIC Z1 for my audi.
It is a double-din and I was wondering if I will need a bezel or if it will just fit perfectly?
Also how about moving those other items down? Will I need something for that?
THANK YOU!!!
[IMG]local://upfiles/19323/901C5782529C4564AF4C4D2085D5C0F6.jpg[/IMG]
[IMG]local://upfiles/19323/76E081E75BF94287B0E7986CC9A2927B.jpg[/IMG]
[IMG]local://upfiles/19323/3639A4D1AA3443959F00AB03BA26E4E2.jpg[/IMG]
SO......
THANK YOU!!!
Good choice. I have that same unit in my ride. Also, you don't have a single DIN sized radio in your ride, the Symphony is a double DIN. What you need to make that Pioneer unit work is the following:
Metra 99-9102: double DIN installation kit
Metra 70-1787: Wire harness to intergrate an aftermarket radio with the stock BOSE amplifiers
Good answer. Just hop to a nearby Circuit City and you'll be able to find those parts. I have the AVN7000 in mine from Eclipse, but I'm planning on switching over to the Z1, because it's just that badass.
ORIGINAL: RLB6
I wrote that without looking. Mine is single-din and it isnt Symphony, its Concert.
Are those still the only parts I need?
[IMG]local://upfiles/19323/300243A207EB4B339651254847F6E940.jpg[/IMG]
ORIGINAL: smokeU
I think its going to be hard to get a double din in there and make it look good...
ORIGINAL: Agro
ERRR MY BAD.
ORIGINAL: RLB6
ORIGINAL: Agro
I dunno about that. Look at the pics I posted at the top from Pioneer that are actually IN an audi. It looks beautiful.
ORIGINAL: smokeU
ORIGINAL: RLB6
OK, now this is a slighty different animal but not too difficult. So, what you need to do is remove that lower pocket and shift the climate controls down. Now, I'm not sure on this but you might need the brackets for the climate control that the symphony equipped A4's have in order to mount it properly. Other than that, still the only parts need afterwards would be the Metra parts.
ORIGINAL: Agro
ERRR MY BAD.
ORIGINAL: RLB6
BTW, check out this link.
http://forums.audiworld.com/a4gen2/msgs/916697.phtml
ORIGINAL: RLB6
