Dounuts & Burnouts
Old Feb 14, 2005 | 12:09 AM
apg96's Avatar
Default Dounuts & Burnouts
I was wondering if it is possible to do a burnout in my car (quattro)? Will it hurt my car in any way? How about dounuts in it?
Old Feb 14, 2005 | 12:17 AM
Doose's Avatar
Default RE: Dounuts & Burnouts
Sure, it's possible. Not likely on dry pavement if you're stock. It eats tires.
Old Feb 14, 2005 | 12:42 AM
AUDI05's Avatar
how would you burn out with a auto-FWD 1.8T?
Old Feb 14, 2005 | 01:03 AM
Jestnomen's Avatar
6th Gear
make sure if you are doing doughnuts not to hold the steering wheel all the way in either direction. Tends to burn out the power steering pump.
AUDI05, please tell me you are kidding. Do not try that with an auto. It's not like a manual where you can just replace the clutch.
Old Feb 14, 2005 | 01:12 AM
AudiGirlie's Avatar
well.....if u put it in neutral...give it some gas......and then rip it into D, you should get your tires to screech, and your tranny to fly out the bottom making REALLY COOL SPARKS!!!!!! LOL!!!!!!
Old Feb 14, 2005 | 01:15 AM
Jestnomen's Avatar
6th Gear
Oh I forgot, it's fun to pour bleach over the tires before you do a burnout. Makes for a TON of white smoke.
Old Feb 14, 2005 | 01:33 AM
aaronamericahall's Avatar
can a 5speed quarttro burn out at least with the chip
Old Feb 14, 2005 | 01:34 AM
apg96's Avatar
if u have an auto u could put it in drive and pull the park brake if its not AWD.
Also hold your brake pedal and let them spin lose.
In my old car (mustang GT) i would rev it up with the clutch in then let it out quickly and i could get a 100ft burnout easyily but that was with a solid rear axle and rwd and a 300 hp V-8.
Old Feb 14, 2005 | 01:42 AM
PandaXpress's Avatar
u can hold on to the brakes and gas it, but front wheel just use the ebrake
Old Feb 14, 2005 | 01:43 AM
apg96's Avatar
the only way to know for sure is to just slam the pedal down. But look above for otherways to make it do one.
