Downshift: 2nd to 1st
Old May 4, 2005 | 10:57 PM
Cameron's Avatar
Default Downshift: 2nd to 1st
Does anyone ever have a problem when downshifting where it seems like your car doesn't want to go into 1st from second? The clutch pedal is all the way down, and it doesn't make any wierd noises... it just doesn't seem like it wants to go into the gear. I was driving today and noticed that it doesn't always want to go into the first gear gate. I haven't noticed any problems downshifting otherwise, and it doesn't seem to do this when the car is at idle. Am I just missing the gear? My car is 2001 1.8T, all stock.
Cameron
Old May 4, 2005 | 11:01 PM
BFlan2001's Avatar
Default RE: Downshift: 2nd to 1st
that's normal....you can replace your snub mount. if it's old, that may improve shifting.
Old May 4, 2005 | 11:02 PM
headshok2002's Avatar
haha i just mentioned that in another post... I have the same problem, and in fact, same goes for my parents 2001 golf 1.8, and their 2002 a4, 1.8t.
I heard that upgrading the snub mount can make a difference with this problem... maybe an allroad trans mount as well? Somebody else chime in here... back up my babbling, or point and laugh.
Old May 4, 2005 | 11:04 PM
BFlan2001's Avatar
that is correct sir, also check your tranny mounts...if they're worn, put in the allroad mounts.
Old May 4, 2005 | 11:07 PM
18T's Avatar
18T
how fast were you going? i dont think its supposed to shift into first unless the speed was already on the low side.
i too hoave trouble shifting into first and R sometimes when idle
Old May 4, 2005 | 11:14 PM
VB05's Avatar
yea i notice if im costing to a light with the clutch down, sometimes its hard to get into first...but when im at a stand still it goes in just fine...
Old May 4, 2005 | 11:16 PM
Cameron's Avatar
I've had this problem from all different speeds (30mph all the way to 5). It really came to my attention today when I was driving over the speedbumps on my street. I slowed down to about 5mph with the clutch in and was just going to put it into 1st to get going again.
I haven't had any problems shifting into 1st or R at idle... don't know what to say.
Cameron
Old May 4, 2005 | 11:18 PM
BFlan2001's Avatar
cameron, how many miles do you have on your car? and do you know if your snub mount or tranny mounts have been replaced before?
Old May 4, 2005 | 11:22 PM
I know the snub is an easy change when you do the T-belt... how hard is the tranny mount to get at?
there is a place that sells a 13 dollar snub mount... i think you mentioned it in another post, bent.
Old May 4, 2005 | 11:31 PM
BFlan2001's Avatar
yea, greedspeed has a snub mount for 13 bucks...there used to be a write-up for the transmission mounts on aw, but i can't find it...
