dragstrip technique
Old Aug 1, 2004 | 12:43 AM
audiboy1618's Avatar
Default RE: dragstrip technique
imolas4, i know "fanning" or "glazing" the clutch isnt good at all, but wouldn't you agree that it is the "fastest" way of the line,if done correctly,even know it fries the clutch?
Old Aug 1, 2004 | 12:22 PM
ImolaS4's Avatar
It's all relative...
If you are slipping the clutch, then no, it's not the fastest way - because it's slipping! If you can get it to bite at higher revs, then that is good. I suggested the rpms above because they are well proved to be within the stock clutch's range for maintaining a bite. (Of course if the clutch has been glazed, then those numbers are too high.) Anything over those revs and the chances increase for slippage, which leads to glazing. Remember, if the clutch is glazing, then it has gone well past the point of just slipping. You want the fastest revs that still allow for the maximum clutch plate bite.
Old Aug 1, 2004 | 06:55 PM
yeah i guess so
UnderPar
B8 Models
May 23, 2009 07:36 PM
RedTTQ
Jan 3, 2008 03:05 PM
fusnowtiger
Mar 23, 2007 10:18 PM
sadize
Nov 14, 2005 09:30 PM
luvin_the_rings
May 2, 2005 05:14 PM
