dv ?
Old Nov 24, 2006 | 02:51 AM
crispycream13's Avatar
Default dv ?
i talked to a guy at a tuning shop, he said if i buy an after market Dv i will have to mantain it like the o-rings in it might blow and ill need to check it. he said i should get a bocsh dv because it has a rubber diaphragm witch wont wear out. is this ture?
Old Nov 24, 2006 | 03:42 AM
Lazer Viking's Avatar
Default RE: dv ?
you need to clean them occasionally... i dont think the wear is really all that high unless your pushing some seruious pressure through there
Old Nov 24, 2006 | 04:21 AM
PandaXpress's Avatar
Default RE: dv ?
FORGE 007 which is also a diaphram DV
the OEM will be cheaper casue the Forge 007s are like 125.00+
Old Nov 24, 2006 | 05:16 AM
Amze's Avatar
Default RE: dv ?
What about the Hyperboost ones? Are those anygood, or should I go with what you mentioned?
Old Nov 24, 2006 | 05:21 AM
Default RE: dv ?
ORIGINAL: Amze
they all should be ok, i never heard anyone talkin about thier new DV becoming faulty
Old Nov 24, 2006 | 05:27 AM
Amze's Avatar
Default RE: dv ?
Aight thanks panda
Old Dec 7, 2006 | 02:14 PM
patty AT forge's Avatar
Default RE: dv ?
The 007 is a piston valve, our diaphragm valves are the (old) DVR, the Eliminator, and the Optimus which is only sold in Japan.
Our piston valves require preiodic cleaning and lubing, this ensures that they will last virtually forever. Diaphragm valves last until they fail, there is no way to determine how long that will be. The internet is full of stories of a bosch valve failing the day the car was chipped... yet some people have them last 20,000 miles with no problems. With the piston style you have more peace of mind...
Old Dec 7, 2006 | 02:25 PM
NuYorka103185's Avatar
Default RE: dv ?
Every aftermarket DV I have seen has been a billet DV and is marketed as unbreakable. Whether or not this is true is another story but i just got one so I hope they were not lying.
Old Dec 7, 2006 | 03:19 PM
BaconBait's Avatar
Default RE: dv ?
ORIGINAL: NuYorka103185
It's not as though it's getting smashed by a hammer or anything. All it's doing is regulating air. If you break a piston DV, you probably bottomed out or put it in a vice.
Thanks for the reminder Patty. I should probably service my 007 with winter rolling around. Any recommended lubricant?
