DV flutter
For some reason recently when i'm in 3rd and 4th gear under heavy load and let off the gas kinda slowly instead of the DV going 'pshhhhhh' it flutters a bit. I've only noticed it under these circumstances though. Is that normal? Or is fluttering a sign of something not working right?
Get a boost gauge. Boost leaks can be hard to find, did he just vissualy inspect or use a boost leak tester of some sort? A boost gauge is a necessity with a turbo for diagnosing things like this.
EDIT:
Oh i see you have a boost gauge... What it read?
EDIT:
[8D].....yea..im not really sure...and if it turns out that this is the case....woah...sweet
