dv install help
Old Dec 31, 2006 | 05:01 AM
chacer99's Avatar
Default dv install help
ok so ive done a search and have found one thread on dv installs but i was wonderinig if anyone could be more thuro and help me get it on diagrams would be helpful thanks
Old Dec 31, 2006 | 05:11 AM
unorthodoxa4's Avatar
Default RE: dv install help
wouldnt mind this too as i literally just finished ordering one from stratmosphere
Old Dec 31, 2006 | 06:12 AM
AteUrV8's Avatar
umm... its pretty much self explanatory... now ive never done one on an audi, but ive done many on dsm's, wrx's, etc...
its probably the easiest DIY outside of putting on an intake or debadging your rear, lol...
look under your hood, locate the stock DV, unbolt the bolts that are holding it on, take off the hose going to the intake, bolt the new one in place, and connect the hose back to the intake...
its pretty self explanatory, just make sure you put the new one on nice and tight so you dont have a nasty boost leak
Old Dec 31, 2006 | 01:23 PM
McGuireDennis's Avatar
Dude you have to jack the car up, take the skid plate off and then rplace it from underneath the car, if you don't have a lift it's kinda hard to do..
Old Dec 31, 2006 | 03:03 PM
ya i thought you had to do it from the underside...
look here-http://http://forums.vwvortex.com/zerothread?id=2192724
also, heres another good link, apparently some of them should be installed bacckwards, reference yours here-http://http://dv.mistertam.com/
Old Dec 31, 2006 | 03:15 PM
new2me's Avatar
It's real easy....
1. Jack up the passenger side of the car and take off the skid plate.
2. Loosen the hose clamps and twist the dv side to side (to break the seal)while pulling it off the hose.
3. Replace the hose clamps and press the new dv into hoses. Tighten the clamps and replace the skid plate.
Old Dec 31, 2006 | 04:02 PM
chacer99's Avatar
ok so regardless i have to jack the car up on my b6 to reach it that was the only info i was looking for i wasnt sure if i could do it any other way
thanks for the help
Old Dec 31, 2006 | 04:09 PM
david9999's Avatar
Never get under a car that is supported by a jack. Use a ramp or a stand.
Old Dec 31, 2006 | 05:03 PM
as long as you have jack stands under it you should be fine, dont rely on just the hyraulic jack
Old Dec 31, 2006 | 05:24 PM
JP A4's Avatar
god its so easy, jack car up, put jack stands up, taek skid plate off(it u stil have it ) find platic stock diverter valve, remove it, put new one on the same way u removed the old one[:-][>:][:'(][:@]
