Dyno Time
Old Dec 23, 2005 | 07:36 AM
Jeff's Avatar
Zombie Defense Force
Default Dyno Time
Just got a dyno and kind of disapointed i made 337whp and 346wtq at 25psi. the porblem is i could of had a ton more but my car was running so rich at the top end that i could not make power, my max power is at 5000 rpms and i can go all the way to 7200, so tomorrow i will see if i can take some fuel out and get better numbers, also i filmed it so ill see if i can make a movie
[IMG]local://upfiles/4588/FCAE1AFBF60843C8826B1184130DEAB7.jpg[/IMG]
Crap thats the 333whp i loaded the wrong one ill fix it later
Old Dec 23, 2005 | 07:41 AM
PandaXpress's Avatar
Default RE: Dyno Time
nice numbers u got there man
337WHP and 346WTQ are still great numbers to me
so it would be like
421HP and 432TQ to the crank with 25% power loss with QUATTRO
Old Dec 23, 2005 | 07:56 AM
prodrive's Avatar
great numbers ,421 hp at the crank ,damn ..
which set-up is this ?
Keep us informed ...
Old Dec 23, 2005 | 08:02 AM
Jeff's Avatar
my little custom t3t4 set up
Old Dec 23, 2005 | 08:22 AM
CheckMyVitals's Avatar
noice. some impressive numbers man. kudos
Old Dec 23, 2005 | 03:38 PM
Jeff's Avatar
thanks, but i still want more, i want to go for 400whp
Old Dec 23, 2005 | 03:46 PM
aRIf's Avatar
wow good numbers..
have you try 1/4 mile ?
How is the respond on short distance race like light to next light... ?
Old Dec 23, 2005 | 03:49 PM
Yuikio's Avatar
Don't blow up your engine for a number. Get it tuned properly, see where you land, and call it good. Don't send a rod through your hood because you turned the boost up to 30psi to get 10 more whp. Those are some badass numbers anyway. You should be comfortably in the 12s.
Old Dec 23, 2005 | 03:52 PM
Jeff's Avatar
ORIGINAL: Yuikio
very good call, im tring be be as safe as possible cus blowing my engine would be the end of me having a car for a long time. i still need suspension cus when i hit the gas i rock back like a boat
Old Dec 23, 2005 | 04:02 PM
VB05's Avatar
if 337whp isnt good enough for u...get a different car and sign over this one to me
